Enables the DHCP relay agent option (option 82).
The default is unconfigured.
This command enables the DHCP relay agent option (option 82), which is inserted into client-originated DHCP packets before they are forwarded to the server.
To disable the DHCP relay agent option (option 82), use the following command:
unconfigure ip-security dhcp-snooping information optionThe following command enable the DHCP relay agent option:
configure ip-security dhcp-snooping information information option
